[geos-devel] [GEOS] #1088: Centroid and InteriorPoint of EMPTY return null
GEOS geos-trac at osgeo.org
Sat Jan 2 21:29:50 PST 2021
 Reporter:  mdavis      |      Owner:  geos-devel@…
     Type:  defect      |     Status:  new
 Priority:  major       |  Milestone:  3.10.0
Component:  Default     |    Version:  3.9.0
 Severity:  Unassigned  |   Keywords:
 Centroid and InteriorPoint of `* EMPTY` return `null` in the C++ API.
 They should return `POINT EMPTY`.
 This is fixed in the C API, but the behaviour should be implemented at the
 C++ level.
Ticket URL: <https://trac.osgeo.org/geos/ticket/1088>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
