[geos-devel] [GEOS] #1088: Centroid and InteriorPoint of EMPTY return null
GEOS geos-trac at osgeo.org
Sat Jan 2 21:36:22 PST 2021
 Reporter:  mdavis      |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.10.0
Component:  Default     |     Version:  3.9.0
 Severity:  Unassigned  |  Resolution:
 Keywords:              |
Comment (by mdavis):
 There is an XML test for EMPTY, but the XMLTester has been patched to
 check for null and create an empty point!  So that needs fixing too.
Ticket URL: <https://trac.osgeo.org/geos/ticket/1088#comment:2>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
