[geos-devel] WKT Precision
Martin Davis
mtnclimb at gmail.com
Wed Jan 6 18:59:39 PST 2021
+1 from me. Faster is Good. It's a relatively simple fallback if ryu
turns out to be unsupportable for some reason. And better to use a
well-tested library (presumably?) than our own hacks.
Maybe C++31 will provide more flexible numeric formatting, but while we're
waiting for that...
On Wed, Jan 6, 2021 at 5:17 PM Paul Ramsey <pramsey at cleverelephant.ca>
wrote:
> Because too many choices is the way to be, I pursued bringing the ryu
> library in for numeric output, the same library that PostgreSQL and PostGIS
> use, and here's a PR
> https://github.com/libgeos/geos/pull/379
> Upside is that it's an actual library for this stuff, it's fast, and it's
> not a string hack. So if we have any concerns about WKT writing
> performance, this is what we should do. However, it's a whole extra library
> in our tree, in case we care.
> Thoughts?
> P
> > On Jan 6, 2021, at 3:07 PM, Paul Ramsey <pramsey at cleverelephant.ca>
> wrote:
> > OK, so the PR <https://github.com/libgeos/geos/pull/378> now pretty
> directly addresses the ticket <https://github.com/libgeos/geos/issues/375>
> about the differences in behavior between setTrim(true) and setTrim(false)
> which previously switched between a positional and sigfigs oriented output,
> and in the PR retains a positional point-of-view throughout.
> > That still leaves the possibility of using some fancy output library,
> like the ones mentioned in https://trac.osgeo.org/geos/ticket/868 or ryu,
> which has been vendored into postgis at 3.1. It would certainly be more
> elegant than the "strip zeroes" code in the PR.
> > P
> >> On Jan 6, 2021, at 12:24 PM, Andrew Hershberger <
> andrew.d.hershberger at gmail.com> wrote:
> >>> For all these reasons and the fact that the current behaviour has
> existed for a long time and is now baked into downstream (those tests in
> GeoSwift!!) I'm inclined to just do nothing.
> >> Please don't let our tests dissuade you 😅. We'll be more than happy to
> adapt to an improved API.
> >> On Wed, Jan 6, 2021 at 11:23 AM Paul Ramsey <pramsey at cleverelephant.ca>
> wrote:
> >>> On Jan 6, 2021, at 9:20 AM, Martin Davis <mtnclimb at gmail.com> wrote:
> >>> Right, I have now seen that std::setprecision switches to scinot if
> the precision is less than the magnitude of the number. Very much not
> ideal IMO. So some way of using std::fixed might be needed to solve this.
> (Not a problem if decimalPlaces is the default 16 though, I think - numbers
> > 10^16 will still be in scinot, but that should be rare).
> >>> So agreed, your PR seems like the right direction. Does it work with
> negative numbers and numbers << 1 ?
> >> No, on re-reading it's still bogus for small numbers. And negatives.
> I'm surprised there's not a standard c++ way to get something like
> std::fixed without the trailing zeroes.
> >> P
> >>> On Wed, Jan 6, 2021 at 9:01 AM Paul Ramsey <pramsey at cleverelephant.ca>
> wrote:
> >>> For interests sake here's a little program that shows the difference
> between std::fixed and the default aka std::defaultfloat. Note that
> defaultfloat (which sort of does "what we want" from a trailing zero point
> of view), also does sigfigs when restricted to a particular precision and
> scientific notation.
> >>> I think if changes are to be made, I like the idea of doing
> >>> - default, take the C++ defaults, don't apply anything. this is a
> change to current behaviour, which applies a default precision
> >>> - if precision is specified, try to do a trimmed, fixed number of
> decimals output, which is kind of what my PR does
> >>> P.
> >>>> On Jan 6, 2021, at 7:54 AM, Martin Davis <mtnclimb at gmail.com> wrote:
> >>>> Well, yes. The current default behaviour seems really unpleasant:
> >>>> POINT (-0.4225977 46.3406448). ==>. POINT (-0.4225977000000000
> 46.3406447999999997)
> >>>> bin/geosop -a "Point (-0.4225977 46.3406448)" -f wkt reducePrecision
> 100
> >>>> POINT (-0.4200000000000000 46.3400000000000034)
> >>>> I agree with Andrew Bell - there is no way GEOS should be trying to
> outsmart the C++ language. And add to that, that setting output precision
> is a perilous hack, since rounding/truncating data pointwise can result in
> invalid topology.
> >>>> Not saying get rid of the setRoundingPrecision, since it's the user's
> decision. But the default should be to just output "full" precision (as
> decided by the standard floating-point output routines, which know about
> weird things like IEEE-754 guard digits). And forget about trimming, since
> the standard output seems to do that just fine.
> >>>> On Wed, Jan 6, 2021 at 7:43 AM Paul Ramsey <pramsey at cleverelephant.ca>
> >>>> Any objections?
> >>>> P
> >>>>> On Jan 6, 2021, at 7:41 AM, Andrew Bell <andrew.bell.ia at gmail.com>
> wrote:
> >>>>> 1) This fight really can't be won without implementing all the
> various things already provided for by a language like C and allowing users
> to make these choices for themselves. GDAL, for example, has its own
> strange logic to do this kind of thing. It's ugly and it's not obvious to a
> user what's going to happen as it's not well-defined by any documentation.
> Some users may want the full precision, and spending a bunch of time
> figuring out if .999997 is significant or not isn't really the role of a
> library like GEOS, IMO. And for some values, scientific notation is what
> you need. This is why %g exists for printf in C.
> >>>>> 2) If you're using a text file for your output, you really don't
> care about size, even if you say you do. Seems like time could be better
> spent elsewhere unless someone is paying for this functionality. Someone
> could certainly reprocess any WKT file to remove digits if they so chose.
> >>>>> On Wed, Jan 6, 2021 at 10:25 AM Martin Davis <mtnclimb at gmail.com>
> wrote:
> >>>>> Is it possible the problem is the use of std:fixed ? (Which is
> invoked if the trim option = FALSE, which is the default).
> >>>>> Currently in WKTWriter.writeNumber there is this code (and the
> defaults invoke fixed precision):
> >>>>> if(! trim) {
> >>>>> ss << std::fixed;
> >>>>> ss << std::setprecision(decimalPlaces >= 0 ? decimalPlaces : 0)
> << d;
> >>>>> This results in the following (as noted on the GeoSwift issue)
> >>>>> This carries too much precision, obviously. I think it might be
> exposing the IEEE-754 guard digits unnecessarily. FP output is notoriously
> tricky, and I suspect it's better to let C++ just do the right thing.
> >>>>> Also, running reducePrecision causes problems, again I suspect due
> to to imprecise FP representation:
> 100
> >>>>> If the std::fixed setting is dropped, the output looks more
> reasonable:
> >>>>> POINT (-0.4225977 46.3406448). ==>. POINT (-0.4225977234 46.3406448)
> >>>>> Check that all input sig digits are shown:
> >>>>> POINT (-0.4225977234 46.3406448) ==> POINT (-0.4225977234 46.3406448)
> >>>>> Reduced precision displays as expected:
> 100
> >>>>> POINT (-0.42 46.34)
> >>>>> Is the "trim" option needed at all?
> >>>>> On Tue, Jan 5, 2021 at 3:41 PM Paul Ramsey <
> pramsey at cleverelephant.ca> wrote:
> >>>>> What do people think is the best practice for outputing WKT
> precision?
> >>>>> _______________________________________________
> >>>>> geos-devel mailing list
> >>>>> geos-devel at lists.osgeo.org
> >>>>> https://lists.osgeo.org/mailman/listinfo/geos-devel
> >>>>> Andrew Bell
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20210106/0af8ac0e/attachment-0001.html>
