[geos-devel] RFC7: Discontinue use of autotools
Daniel Baston
dbaston at gmail.com
Fri Jan 8 14:45:42 PST 2021
> It's relevant to the extent that _dropping_ cmake would also resolve
> the "need to do double work" issue, if it wasn't for Windows.
It doesn't resolve the issue, because we'd need to re-introduce NMake. If
you're suggesting that we drop Windows, please make that motion separately.
I'm pretty sure the majority of the above committers (also)
> use autotools, so the first motivation is not enough.
I am not using autotools with GEOS but can't speak for others.
Dan
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20210108/36859776/attachment.html>
