[geos-devel] [GEOS] #1094: CMake issue with berrie32 (raspberry pi)
GEOS geos-trac at osgeo.org
Sun Jan 17 08:50:46 PST 2021
 Reporter:  robe        |      Owner:  geos-devel@…
     Type:  defect      |     Status:  new
 Priority:  minor       |  Milestone:  3.9.1
Component:  Default     |    Version:  3.9.0
 Severity:  Unassigned  |   Keywords:
 I recently switched from autotools to cmake build on the berrie bots. I
 don't think this is a new issue as it was failing in autotools as well as
 I recall.
 The 64-bit chain is running fine under cmake (was broken in autotools),
 but 32-bit chain is having issues.
 32-bit chain error is below:
 Since there are way fewer 32-bit os now than in past, I consider this a
 minor issue.
 23:11:24 [ 57%] Building CXX object
 CMakeFiles/geos.dir/src/triangulate/quadedge/QuadEdgeSubdivision.cpp.o
 23:11:27 In file included from /usr/include/c++/8/vector:69,
 23:11:27                  from
 /home/jenkins/workspace/GEOS_Worker_Run/label/berrie/dae18d6c6555b4b129ec053af3a50f7045fd5413/include/geos/triangulate/quadedge/QuadEdgeSubdivision.h:27,
 23:11:27                  from
 /home/jenkins/workspace/GEOS_Worker_Run/label/berrie/dae18d6c6555b4b129ec053af3a50f7045fd5413/src/triangulate/quadedge/QuadEdgeSubdivision.cpp:19:
 23:11:27 /usr/include/c++/8/bits/vector.tcc: In member function ‘void
 std::vector<_Tp, _Alloc>::_M_realloc_insert(std::vector<_Tp,
 _Alloc>::iterator, _Args&& ...) [with _Args = {const
 geos::geom::Coordinate&}; _Tp = geos::geom::Coordinate; _Alloc =
 std::allocator<geos::geom::Coordinate>]’:
 23:11:27 /usr/include/c++/8/bits/vector.tcc:413:7: note: parameter passing
 for argument of type ‘std::vector<geos::geom::Coordinate>::iterator’ {aka
 ‘__gnu_cxx::__normal_iterator<geos::geom::Coordinate*,
 std::vector<geos::geom::Coordinate> >’} changed in GCC 7.1
 23:11:27        vector<_Tp, _Alloc>::
 23:11:27        ^~~~~~~~~~~~~~~~~~~
 23:11:27 In file included from /usr/include/c++/8/vector:64,
 23:11:27                  from
 23:11:27                  from
 23:11:27 /usr/include/c++/8/bits/stl_vector.h: In member function
 ‘std::unique_ptr<geos::geom::Geometry>
 geos::triangulate::quadedge::QuadEdgeSubdivision::getVoronoiCellEdge(const
 geos::triangulate::quadedge::QuadEdge*, const
 geos::geom::GeometryFactory&)’:
 23:11:27 /usr/include/c++/8/bits/stl_vector.h:1085:4: note: parameter
 passing for argument of type
 std::vector<geos::geom::Coordinate> >’ changed in GCC 7.1
 23:11:27     _M_realloc_insert(end(), __x);
 23:11:28 /usr/include/c++/8/bits/stl_vector.h: In member function
 geos::triangulate::quadedge::QuadEdgeSubdivision::getVoronoiCellPolygon(const
 23:11:28 /usr/include/c++/8/bits/stl_vector.h:1085:4: note: parameter
 23:11:28     _M_realloc_insert(end(), __x);
 23:11:28     ^~~~~~~~~~~~~~~~~
 23:11:29 [ 57%] Building CXX object
 CMakeFiles/geos.dir/src/triangulate/quadedge/TrianglePredicate.cpp.o
 CMakeFiles/geos.dir/src/triangulate/quadedge/Vertex.cpp.o
 23:11:31 [ 57%] Building CXX object
 CMakeFiles/geos.dir/src/util/Assert.cpp.o
 23:11:32 [ 57%] Building CXX object
 CMakeFiles/geos.dir/src/util/GeometricShapeFactory.cpp.o
 23:11:35 [ 58%] Building CXX object
 CMakeFiles/geos.dir/src/util/Interrupt.cpp.o
 CMakeFiles/geos.dir/src/util/Profiler.cpp.o
 23:11:37 In file included from /usr/include/c++/8/vector:69,
 23:11:37                  from
 /home/jenkins/workspace/GEOS_Worker_Run/label/berrie/dae18d6c6555b4b129ec053af3a50f7045fd5413/include/geos/profiler.h:25,
 23:11:37                  from
 /home/jenkins/workspace/GEOS_Worker_Run/label/berrie/dae18d6c6555b4b129ec053af3a50f7045fd5413/src/util/Profiler.cpp:15:
 23:11:37 /usr/include/c++/8/bits/vector.tcc: In member function ‘void
 std::chrono::duration<long long int, std::ratio<1, 1000000> >&}; _Tp =
 std::chrono::duration<long long int, std::ratio<1, 1000000> >; _Alloc =
 std::allocator<std::chrono::duration<long long int, std::ratio<1, 1000000>
 23:11:37 /usr/include/c++/8/bits/vector.tcc:413:7: note: parameter passing
 for argument of type ‘std::vector<std::chrono::duration<long long int,
 std::ratio<1, 1000000> > >::iterator’ {aka
 ‘__gnu_cxx::__normal_iterator<std::chrono::duration<long long int,
 std::ratio<1, 1000000> >*, std::vector<std::chrono::duration<long long
 int, std::ratio<1, 1000000> > > >’} changed in GCC 7.1
 23:11:37        vector<_Tp, _Alloc>::
 23:11:37        ^~~~~~~~~~~~~~~~~~~
 23:11:37 In file included from /usr/include/c++/8/vector:64,
 23:11:37                  from
 23:11:37                  from
 23:11:37 /usr/include/c++/8/bits/stl_vector.h: In member function ‘void
 geos::util::Profiler::stop(std::__cxx11::string)’:
 23:11:37 /usr/include/c++/8/bits/stl_vector.h:1085:4: note: parameter
 int, std::ratio<1, 1000000> > > >’ changed in GCC 7.1
 23:11:37     _M_realloc_insert(end(), __x);
 23:11:37 [ 58%] Building CXX object
 CMakeFiles/geos.dir/src/util/math.cpp.o
 23:11:38 [ 58%] Building C object CMakeFiles/geos.dir/src/deps/ryu/d2s.c.o
 23:11:38 cc1: warning: command line option ‘-fno-implicit-inline-
 templates’ is valid for C++/ObjC++ but not for C
 23:11:38
 /home/jenkins/workspace/GEOS_Worker_Run/label/berrie/dae18d6c6555b4b129ec053af3a50f7045fd5413/src/deps/ryu/d2s.c:
 In function ‘to_chars_uint64’:
 23:11:38
 /home/jenkins/workspace/GEOS_Worker_Run/label/berrie/dae18d6c6555b4b129ec053af3a50f7045fd5413/src/deps/ryu/d2s.c:534:9:
 warning: conversion to ‘int’ from ‘uint32_t’ {aka ‘unsigned int’} may
 change the sign of the result [-Wsign-conversion]
 23:11:38   return i;
 23:11:38          ^
 23:11:38
 In function ‘to_chars_fixed’:
 23:11:38
 /home/jenkins/workspace/GEOS_Worker_Run/label/berrie/dae18d6c6555b4b129ec053af3a50f7045fd5413/src/deps/ryu/d2s.c:553:28:
 warning: conversion to ‘uint32_t’ {aka ‘unsigned int’} from ‘int32_t’ {aka
 ‘int’} may change the sign of the result [-Wsign-conversion]
 23:11:38    trailing_integer_zeros = exp;
 23:11:38                             ^~~
 23:11:38
 /home/jenkins/workspace/GEOS_Worker_Run/label/berrie/dae18d6c6555b4b129ec053af3a50f7045fd5413/src/deps/ryu/d2s.c:561:34:
 23:11:38     int32_t digits_to_trim = -exp - precision;
 23:11:38                                   ^
 23:11:38
 /home/jenkins/workspace/GEOS_Worker_Run/label/berrie/dae18d6c6555b4b129ec053af3a50f7045fd5413/src/deps/ryu/d2s.c:561:29:
 warning: conversion to ‘int32_t’ {aka ‘int’} from ‘uint32_t’ {aka
 ‘unsigned int’} may change the sign of the result [-Wsign-conversion]
 23:11:38                              ^
 23:11:38
 /home/jenkins/workspace/GEOS_Worker_Run/label/berrie/dae18d6c6555b4b129ec053af3a50f7045fd5413/src/deps/ryu/d2s.c:584:14:
 23:11:38       olength -= digits_to_trim;
 23:11:38               ^~
 23:11:38
 /home/jenkins/workspace/GEOS_Worker_Run/label/berrie/dae18d6c6555b4b129ec053af3a50f7045fd5413/src/deps/ryu/d2s.c:601:29:
 23:11:38                              ^~~
 23:11:38
 /home/jenkins/workspace/GEOS_Worker_Run/label/berrie/dae18d6c6555b4b129ec053af3a50f7045fd5413/src/deps/ryu/d2s.c:609:34:
 23:11:38     integer_part_length = olength - nexp;
 23:11:38                                   ^
 23:11:38
 /home/jenkins/workspace/GEOS_Worker_Run/label/berrie/dae18d6c6555b4b129ec053af3a50f7045fd5413/src/deps/ryu/d2s.c:611:50:
 warning: conversion to ‘int32_t’ {aka ‘const int’} from ‘uint32_t’ {aka
 23:11:38     if (decimal_part < pow_10(decimal_part_length - 1))
 23:11:38                               ~~~~~~~~~~~~~~~~~~~~^~~
 23:11:38
 /home/jenkins/workspace/GEOS_Worker_Run/label/berrie/dae18d6c6555b4b129ec053af3a50f7045fd5413/src/deps/ryu/d2s.c:623:33:
 23:11:38     leading_decimal_zeros = nexp - olength;
 23:11:38                                  ^
 23:11:40 [ 58%] Linking CXX shared library lib/libgeos.so
 23:11:41 /usr/bin/ld:
 CMakeFiles/geos.dir/src/noding/BasicSegmentString.cpp.o:(.rodata+0x0):
 multiple definition of `typeinfo name for
 geos::noding::BasicSegmentString';
 CMakeFiles/geos.dir/src/inlines.cpp.o:(.rodata+0x50): first defined here
 CMakeFiles/geos.dir/src/noding/BasicSegmentString.cpp.o:(.data.rel.ro+0x0):
 multiple definition of `typeinfo for geos::noding::BasicSegmentString';
 CMakeFiles/geos.dir/src/inlines.cpp.o:(.data.rel.ro+0x18): first defined
 here
 CMakeFiles/geos.dir/src/noding/BasicSegmentString.cpp.o:(.data.rel.ro+0xc):
 multiple definition of `vtable for geos::noding::BasicSegmentString';
 CMakeFiles/geos.dir/src/inlines.cpp.o:(.data.rel.ro+0xa0): first defined
 here
 CMakeFiles/geos.dir/src/noding/MCIndexNoder.cpp.o:(.data.rel.ro+0x30):
 multiple definition of `vtable for geos::noding::MCIndexNoder';
 CMakeFiles/geos.dir/src/inlines.cpp.o:(.data.rel.ro+0xc4): first defined
 here
 CMakeFiles/geos.dir/src/noding/MCIndexNoder.cpp.o:(.rodata+0x34): multiple
 definition of `typeinfo name for geos::noding::MCIndexNoder';
 CMakeFiles/geos.dir/src/inlines.cpp.o:(.rodata+0x74): first defined here
 CMakeFiles/geos.dir/src/noding/MCIndexNoder.cpp.o:(.data.rel.ro+0xc):
 multiple definition of `typeinfo for geos::noding::MCIndexNoder';
 CMakeFiles/geos.dir/src/inlines.cpp.o:(.data.rel.ro+0x24): first defined
 here
 23:11:41 collect2: error: ld returned 1 exit status
 23:11:41 make[2]: *** [CMakeFiles/geos.dir/build.make:5379:
 lib/libgeos.so.3.10.0dev] Error 1
 23:11:41 make[1]: *** [CMakeFiles/Makefile2:585: CMakeFiles/geos.dir/all]
 Error 2
 23:11:41 make: *** [Makefile:163: all] Error 2
 23:11:41 Test project
 /home/jenkins/workspace/GEOS_Worker_Run/label/berrie/dae18d6c6555b4b129ec053af3a50f7045fd5413/build
 23:11:41         Start   1: unit-algorithm-Angle
 23:11:41 Could not find executable
 /home/jenkins/workspace/GEOS_Worker_Run/label/berrie/dae18d6c6555b4b129ec053af3a50f7045fd5413/build/bin/test_geos_unit
Ticket URL: <https://trac.osgeo.org/geos/ticket/1094>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
