[geos-devel] [GEOS] #1094: CMake issue with berrie (32-bit raspberry pi)
geos-trac at osgeo.org
Sat Jan 23 13:39:40 PST 2021
Reporter: robe | Owner: geos-devel@…
Type: defect | Status: new
Priority: minor | Milestone: 3.9.1
Component: Default | Version: 3.9.0
Severity: Unassigned | Resolution:
Keywords: |
Comment (by bowguy):
Fyi
Using make instead of CMake gives the same error
/usr/bin/ld: noding/.libs/libnoding.a(BasicSegmentString.o):(.rodata+0x0):
multiple definition of `typeinfo name for
geos::noding::BasicSegmentString'; .libs/inlines.o:(.rodata+0x6f0): first
defined here
/usr/bin/ld:
noding/.libs/libnoding.a(BasicSegmentString.o):(.data.rel.ro+0x0):
multiple definition of `typeinfo for geos::noding::BasicSegmentString';
.libs/inlines.o:(.data.rel.ro+0x18): first defined here
/usr/bin/ld:
noding/.libs/libnoding.a(BasicSegmentString.o):(.data.rel.ro+0xc):
multiple definition of `vtable for geos::noding::BasicSegmentString';
.libs/inlines.o:(.data.rel.ro+0x94): first defined here
Ticket URL: <https://trac.osgeo.org/geos/ticket/1094#comment:4>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
