[geos-devel] [GEOS] #1097: Dropped holes when buffer(0) -ing a valid geometry
geos-trac at osgeo.org
Mon Jan 25 19:26:59 PST 2021
Reporter: astronomiser | Owner: geos-devel@…
Type: defect | Status: new
Priority: minor | Milestone:
Component: Default | Version: 3.8.1
Severity: Unassigned | Keywords: buffer
Passing along this bug report from
[https://github.com/Toblerity/Shapely/issues/1069 the Shapely github].
[https://github.com/Toblerity/Shapely/files/5845907/shape.txt The WKT in a
text file]
Running buffer(0) leaves the geometry mostly unchanged but there is a
group of holes which are removed in the lower right of the geometry.
I was able to replicate this behavior in PostGIS (w/ GEOS 3.5). The user
is using Shapely with GEOS 3.8.1. Buffering the geometry in JTS did not
produce the same effect.
Ticket URL: <https://trac.osgeo.org/geos/ticket/1097>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
