[geos-devel] [GEOS] #1119: Buffer memory issue
geos-trac at osgeo.org
Thu Jun 3 09:51:58 PDT 2021
Reporter: kalenik | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.9.2
Component: Default | Version: 3.9.0
Severity: Unassigned | Resolution:
Keywords: |
Comment (by kalenik):
My case is calculation of buffers for heavy geometries in parallel and the
problem is that at some point I am running out of memory and process
crashes badly. I understand that with current implementation buffer
calculation for heavy geometries is memory consuming process but I would
prefer GEOS to throw an exception instead of crashing.
Here is the C snippet and geometry file I used to reproduce the problem.
Likely you would have to limit process memory to reproduce the OOM.
https://gist.github.com/kalenikaliaksandr/f84bc2fe3f9c5e2a01c63860477f9243
(sorry, geom is too large for attachments)
Ticket URL: <https://trac.osgeo.org/geos/ticket/1119#comment:3>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
