[geos-devel] [GEOS] #1119: Buffer memory issue
geos-trac at osgeo.org
Thu Jun 3 10:26:46 PDT 2021
Reporter: kalenik | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.9.2
Component: Default | Version: 3.9.0
Severity: Unassigned | Resolution:
Keywords: |
Comment (by komzpa):
@pramsey this thingy takes down Postgres cluster from SQL level ST_Buffer.
Expectation is that query will fail at most, not whole cluster.
Ticket URL: <https://trac.osgeo.org/geos/ticket/1119#comment:5>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
