[geos-devel] [GEOS] #1104: error: conversion from 'std::size_t' {aka 'long long unsigned int'} to 'long int' may change value [-Werror=conversion]
GEOS geos-trac at osgeo.org
Tue Mar 2 13:33:46 PST 2021
 Reporter:  robe        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.10.0
Component:  Default     |     Version:  master
 Severity:  Unassigned  |  Resolution:
 Keywords:              |
Old description:
> Seeing this error on winnie's gcc 8.1 64-bit builds.  Strk says he is
> seeing the same errors.
> This is with cmake 3.15.4.  I'm going to up it and see if things improve.
> -- GEOS: Build type: Release
> -- GEOS: Run-time output: E:/jenkins/geos/branches/build64cmake3.10/bin
> -- GEOS: Archives output: E:/jenkins/geos/branches/build64cmake3.10/lib
> -- The C compiler identification is GNU 8.1.0
> -- The CXX compiler identification is GNU 8.1.0
> -- Check for working C compiler: C:/ming64gcc81/mingw64/bin/gcc.exe
> -- Check for working C compiler: C:/ming64gcc81/mingw64/bin/gcc.exe --
> works
> -- Detecting C compiler ABI info
> -- Detecting C compiler ABI info - done
> -- Detecting C compile features
> -- Detecting C compile features - done
> -- Check for working CXX compiler: C:/ming64gcc81/mingw64/bin/g++.exe
> -- Check for working CXX compiler: C:/ming64gcc81/mingw64/bin/g++.exe --
> works
> -- Detecting CXX compiler ABI info
> -- Detecting CXX compiler ABI info - done
> -- Detecting CXX compile features
> -- Detecting CXX compile features - done
> -- GEOS: Version 3.10.0dev
> -- GEOS: C API Version 1.15.0
> -- GEOS: JTS port 1.17.0
> -- GEOS: Require C++11
> -- GEOS: Function inlining ENABLED
> -- GEOS: Developer mode ENABLED
> -- GEOS: Configured 'dist' target
> -- GEOS: Configured 'distcheck' target
> -- Configuring done
> -- Generating done
> [ 98%] Building CXX object
> util/geosop/CMakeFiles/geosop.dir/GeosOp.cpp.obj
> E:/jenkins/geos/branches/3.10cmake/util/geosop/GeosOp.cpp: In function
> 'bool isWKTLiteral(std::__cxx11::string)':
> E:/jenkins/geos/branches/3.10cmake/util/geosop/GeosOp.cpp:171:32: error:
> conversion from
> 'std::__iterator_traits<__gnu_cxx::__normal_iterator<char*,
> std::__cxx11::basic_string<char> >, void>::difference_type' {aka 'long
> long int'} to 'long int' may change value [-Werror=conversion]
>      long numLParen = std::count(s.begin(), s.end(), '(');
> E:/jenkins/geos/branches/3.10cmake/util/geosop/GeosOp.cpp: In member
> function 'void GeosOp::executeUnary(GeomFunction*)':
> E:/jenkins/geos/branches/3.10cmake/util/geosop/GeosOp.cpp:355:47: error:
>          vertexCount += geomA[i]->getNumPoints();
> function 'void GeosOp::executeBinary(GeomFunction*)':
> E:/jenkins/geos/branches/3.10cmake/util/geosop/GeosOp.cpp:366:52: error:
>              vertexCount += geomA[ia]->getNumPoints();
> E:/jenkins/geos/branches/3.10cmake/util/geosop/GeosOp.cpp:367:52: error:
>              vertexCount += geomB[ib]->getNumPoints();
> At global scope:
> cc1plus.exe: error: unrecognized command line option '-Wno-unknown-
> warning-option' [-Werror]
> cc1plus.exe: all warnings being treated as errors
> make[2]: *** [util/geosop/CMakeFiles/geosop.dir/build.make:64:
> util/geosop/CMakeFiles/geosop.dir/GeosOp.cpp.obj] Error 1
> make[1]: *** [CMakeFiles/Makefile2:1962:
> util/geosop/CMakeFiles/geosop.dir/all] Error 2
> make: *** [Makefile:163: all] Error 2
> I'm seeing a bunch of errors on 32-bit but will look at those closer
New description:
 works
 works
 -- Configuring done
 -- Generating done
 [ 98%] [32mBuilding CXX object
 util/geosop/CMakeFiles/geosop.dir/GeosOp.cpp.obj[0m
 conversion from
 At global scope:
Comment (by strk):
 I've filed #1105 for the last error about unrecognized option, which I
 also get
Ticket URL: <https://trac.osgeo.org/geos/ticket/1104#comment:1>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
