[geos-devel] [GEOS] #1103: Target "tinyxml2" of type OBJECT_LIBRARY may not be linked into another target.
GEOS geos-trac at osgeo.org
Tue Mar 2 13:52:46 PST 2021
target.
 Reporter:  strk                   |       Owner:  geos-devel@…
     Type:  defect                 |      Status:  closed
 Priority:  blocker                |   Milestone:  3.10.0
Component:  Build/Install (cmake)  |     Version:  master
 Severity:  Critical               |  Resolution:  fixed
 Keywords:                         |
Changes (by strk):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 Confirmed fix on [c6abbf9f980bd21d4a0ce2818bc0480a4707afc9/git]
Ticket URL: <https://trac.osgeo.org/geos/ticket/1103#comment:7>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
