[geos-devel] [GEOS] #1106: error: ‘GEOSDensify_r’ was not declared in this scope
geos-trac at osgeo.org
Tue Mar 2 13:54:18 PST 2021
Reporter: strk | Owner: geos-devel@…
Type: defect | Status: new
Priority: blocker | Milestone: 3.10.0
Component: Build/Install (cmake) | Version: master
Severity: Unassigned | Keywords:
usr/src/geos/geos/src/master/capi/geos_c.cpp: In function
‘geos::geom::Geometry* GEOSDensify(const geos::geom::Geometry*, double)’:
/usr/src/geos/geos/src/master/capi/geos_c.cpp:433:16: error:
return GEOSDensify_r(handle, g, tolerance);
/usr/src/geos/geos/src/master/capi/geos_c.cpp:433:16: note: suggested
alternative: ‘GEOSDensify’
GEOSDensify
This is with current master branch
[c6abbf9f980bd21d4a0ce2818bc0480a4707afc9/git]
Ticket URL: <https://trac.osgeo.org/geos/ticket/1106>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
