[geos-devel] [GEOS] #1104: error: conversion from 'std::size_t' {aka 'long long unsigned int'} to 'long int' may change value [-Werror=conversion]
geos-trac at osgeo.org
Mon Mar 8 22:22:29 PST 2021
Reporter: robe | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.10.0
Component: Default | Version: master
Severity: Unassigned | Resolution:
Keywords: |
Comment (by robe):
Only thing is why am I the only one affected by this if it's just a type
issue or is my type being detected incorrectly.
Compile works on my mingw64 32-bit but is failing on my mingw64 64-bit.
Ticket URL: <https://trac.osgeo.org/geos/ticket/1104#comment:4>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
