[geos-devel] [GEOS] #1094: CMake issue with berrie (32-bit raspberry pi)
GEOS geos-trac at osgeo.org
Fri Mar 12 20:39:27 PST 2021
 Reporter:  robe        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  closed
 Priority:  minor       |   Milestone:  3.9.2
Component:  Default     |     Version:  3.9.0
 Severity:  Unassigned  |  Resolution:  fixed
 Keywords:              |
Changes (by robe):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 dropping the inlines.cpp seems to have fixed berrie's issues
 https://debbie.postgis.net/job/GEOS_Worker_Run/label=berrie/1061/console
Ticket URL: <https://trac.osgeo.org/geos/ticket/1094#comment:8>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
