[geos-devel] Gitea 3.10.0dev cmake broken
Roger Bivand Roger.Bivand at nhh.no
Thu May 6 05:19:07 PDT 2021
I ran:
$ cat 447.diff | patch -p1 -c -b
patching file tools/CMakeLists.txt
patching file tools/geos-config.cmake
patching file tools/geos-config.in
patching file tools/geos.pc.cmake
apparently successfully, but then see (running in a fresh  build
directory, CCACHE is turned off):
$ cmake -DCMAKE_BUILD_TYPE=Release ..
-- GEOS: Function inlining ENABLED
-- GEOS: Developer mode ENABLED
CMake Error: File /home/rsb/topics/gitea/geos/tools/geos-config.cmake does
not exist.
CMake Error at tools/CMakeLists.txt:18 (configure_file):
   configure_file Problem configuring file
CMake Error: File /home/rsb/topics/gitea/geos/tools/geos.pc.cmake does not
exist.
CMake Error at tools/CMakeLists.txt:32 (configure_file):
so there seen to be cmake specs still expecting the deleted files to be
present.
Roger
On Thu, 6 May 2021, Mike Taves wrote:
> On Thu, 6 May 2021 at 18:59, Roger Bivand <Roger.Bivand at nhh.no> wrote:
>> Thanks - what would be the best way for me to patch my instance of the
>> gitea repo to check that this works? Can I get a regular diff from a git
>> PR?
> Just add .diff to the address:
> https://github.com/libgeos/geos/pull/447.diff
> And yes, please try it out! It would be nice to iron out these issues
> before getting close to the next release.
Roger Bivand
Emeritus Professor
Department of Economics, Norwegian School of Economics,
Postboks 3490 Ytre Sandviken, 5045 Bergen, Norway.
e-mail: Roger.Bivand at nhh.no
https://orcid.org/0000-0003-2392-6140
https://scholar.google.no/citations?user=AWeghB0AAAAJ&hl=en
