[geos-devel] Gitea 3.10.0dev cmake broken
Even Rouault even.rouault at spatialys.com
Fri May 7 03:48:29 PDT 2021
Roger,
> $ pkg-config geos --libs
> -L/usr/local/lib -lgeos_c
> which remains curious.
Check if you don't have a /usr/local/lib/pkgconfig/geos.pc file
and/or set PKG_CONFIG_PATH=/usr/local/lib64/pkgconfig
Even
http://www.spatialys.com
