[geos-devel] [GEOS] #1143: Release distribution contains generated files with "dev" in version
    geos-trac at osgeo.org
    Tue Nov  2 13:05:23 PDT 2021
 Reporter:  Mike Taves  |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.10.1
Component:  Default     |     Version:  main
 Severity:  Unassigned  |  Resolution:
 Keywords:              |
Comment (by Mike Taves):
 Sure, the "from_trac" subdir is from the download.osgeo link above, and
 "from_3.10_branch" is what I get from the 3.10 branch using the steps
 above, with an edit to Version.txt
 $ diff -qr /tmp/from_trac/ /tmp/from_3.10_branch/
 Files /tmp/from_trac/geos-3.10.1/CMakeLists.txt and
 /tmp/from_3.10_branch/geos-3.10.1/CMakeLists.txt differ
 Only in /tmp/from_3.10_branch/geos-3.10.1: doc
 Only in /tmp/from_trac/geos-3.10.1: doxygen
 Only in /tmp/from_3.10_branch/geos-3.10.1/examples: capi_prepared.cpp
 Only in /tmp/from_3.10_branch/geos-3.10.1/examples: capi_read.cpp
 Only in /tmp/from_3.10_branch/geos-3.10.1/examples: capi_read_ts.cpp
 Files /tmp/from_trac/geos-3.10.1/include/geos/noding/snap/SnappingNoder.h
 and
 /tmp/from_3.10_branch/geos-3.10.1/include/geos/noding/snap/SnappingNoder.h
 differ
 Files /tmp/from_trac/geos-3.10.1/NEWS and
 /tmp/from_3.10_branch/geos-3.10.1/NEWS differ
 Files /tmp/from_trac/geos-3.10.1/README.md and
 /tmp/from_3.10_branch/geos-3.10.1/README.md differ
 Files /tmp/from_trac/geos-3.10.1/src/noding/snap/SnappingNoder.cpp and
 /tmp/from_3.10_branch/geos-3.10.1/src/noding/snap/SnappingNoder.cpp differ
 Only in /tmp/from_trac/geos-3.10.1/tests/unit/capi: GEOSCoveredByTest.cpp
 Only in /tmp/from_trac/geos-3.10.1/tests/unit/capi: GEOSCoversTest.cpp
 Only in /tmp/from_trac/geos-3.10.1/tests/unit/capi: GEOSCrossesTest.cpp
 Only in /tmp/from_trac/geos-3.10.1/tests/unit/capi: GEOSDisjointTest.cpp
 GEOSGeomToHEX_bufTest.cpp
 GEOSGeomToWKB_bufTest.cpp
 Only in /tmp/from_trac/geos-3.10.1/tests/unit/capi: GEOSGeomTypeIdTest.cpp
 GEOSGetExteriorRingTest.cpp
 GEOSGetGeometryNTest.cpp
 GEOSGetInteriorRingNTest.cpp
 Only in /tmp/from_trac/geos-3.10.1/tests/unit/capi: GEOSOverlapsTest.cpp
 GEOSRelatePatternTest.cpp
 Only in /tmp/from_trac/geos-3.10.1/tests/unit/capi: GEOSRelateTest.cpp
 GEOSSymDifferencePrecTest.cpp
 GEOSSymDifferenceTest.cpp
 Only in /tmp/from_trac/geos-3.10.1/tests/unit/capi: GEOSTouchesTest.cpp
 GEOSUnaryUnionPrecTest.cpp
 GEOSUnionCascadedTest.cpp
 Only in /tmp/from_trac/geos-3.10.1: web
Ticket URL: <https://trac.osgeo.org/geos/ticket/1143#comment:4>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
