[geos-devel] Continuous publishing of GEOS webpage (was: GEOS RFC 10 - Move Project to GitHub)
Paul Ramsey
pramsey at cleverelephant.ca
Wed Nov 3 07:59:33 PDT 2021
Yes, please don't do this, or at least please don't be be put out if I next request you take it down. I don't want more bespoke scripts and hooks, I want fewer, that is (one of the) points of RFC10.
P.
> On Nov 2, 2021, at 7:56 PM, Sandro Santilli <strk at kbt.io> wrote:
> On Tue, Nov 02, 2021 at 09:12:04AM -0400, Regina Obe wrote:
>>> On Fri, Oct 29, 2021 at 12:13:19PM -0700, Paul Ramsey wrote:
>>>> http://libgeos.org/development/rfcs/rfc10/
>>> That's a 404 for me.
>> It will come back once pramsey has reset the config. It's really because gh-pages is a branch of our core github branch
>> and that is not mirrored. This problem will be solved once GEOS moves to Github.
> I spent a few minutes setting up the website on our own infra,
> so now the RFC can be read here:
> https://geos.osgeo.org/web/development/rfcs/rfc10/
> That website should now be updated everytime a commit
> is pushed to the "main" branch on git.osgeo.org.
> I made it accessible under the /web subdir as experimental,
> but moving it one dir above would be easy (current top-dir
> redirects to trac.osgeo.org/geos instead).
> The Gitea update setup is controlled here:
> https://git.osgeo.org/gitea/geos/geos/settings/hooks
> The server-side script responding to the URL hit by the hook
> was made by me manually (as experimental). It's a 4 lines script
> updating a local clone of the git repository, tweaking a configuration
> and running hugo. The host machine holding the script was configured
> to run the script upon receiving a request on an URL (again this was
> done manually but could be stabilized by using ansible to setup).
> --strk;
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geos-devel
