[geos-devel] 3.10.0beta1
Sebastiaan Couwenberg
sebastic at xs4all.nl
Fri Oct 1 01:47:29 PDT 2021
Another issue, this one cause by the switch to CMake.
The autotools build resulted in libgeos-X.Y.Z.so, which was also its
SONAME, and the libgeos.so symlink to it.
The cmake builds results in libgeos.so.X.Y.Zpre, which is also its
The pre-release word should not be part of the filename nor SOVERSION.
The attached patch fixes the issue.
Kind Regards,
Bas
GPG Key ID: 4096R/6750F10AE88D4AF1
Fingerprint: 8182 DE41 7056 408D 6146 50D1 6750 F10A E88D 4AF1
Type: text/x-patch
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20211001/8eb79b3b/attachment.bin>
