[geos-devel] Should DistanceWithin(EMPTY, ANYTHING, ANYDISTANCE) always return false ?
Paul Ramsey
pramsey at cleverelephant.ca
Mon Oct 4 15:44:36 PDT 2021
Doesn't seem super important to back-port. To the extent that it's extant behaviour, I think we should just Let It Be.
P
> On Oct 4, 2021, at 3:43 PM, Sandro Santilli <strk at kbt.io> wrote:
> I pushed a commit to main branch always returning false.
> Same on the PostGIS side, but I don't know up to which version I
> should backport that. If you have old versions around, could you
> please leave a comment in https://trac.osgeo.org/postgis/ticket/5008 ?
> --strk;
> On Mon, Oct 04, 2021 at 07:56:34PM +0300, Darafei "Komяpa" Praliaskouski wrote:
>> Points on infinite distance are still on the extended R2+ plane. The empty
>> points aren't.
>> This one should be "always false", and make sure that "POINT(INF INF)" is
>> at INF distance from anything (can be true). POINT(Inf Inf) != POINT(NaN
>> NaN) in this aspect.
>> On Mon, Oct 4, 2021 at 6:50 PM Paul Ramsey <pramsey at cleverelephant.ca>
>> wrote:
>>> https://trac.osgeo.org/postgis/wiki/DevWikiEmptyGeometry
>>> pramsey=# select st_distance('POINT(1 1)','POINT EMPTY');
>>> st_distance
>>> (1 row)
>>> Interesting note in the wiki about returning NULL for DWithin.
>>> Current behaviour.
>>> pramsey=# select st_dwithin('POINT(1 1)','POINT EMPTY', 1);
>>> st_dwithin
>>> f
>>> (1 row)
>>> pramsey=# select st_dwithin('POINT(1 1)','POINT EMPTY', 'Inf'::float8);
>>> st_dwithin
>>> t
>>> (1 row)
>>> I could see going for "always false" since we're almost there for non-inf
>>> values.
>>> P
>>>> On Oct 4, 2021, at 8:08 AM, Sandro Santilli <strk at kbt.io> wrote:
>>>> On Mon, Oct 04, 2021 at 05:02:24PM +0200, Sandro Santilli wrote:
>>>>> I'd think yes, honestly, but the current code returns TRUE sometimes,
>>>>> particularly for MAXDISTANCE being Infinite...
>>>>> As I think GEOS is not being used by phylosophers, I can't find any
>>>>> reason why would anyone want a TRUE result from a DistanceWithin()
>>>>> query involving an EMPTY geometry.
>>>> We have the same issue on PostGIS:
>>>> --strk;
>>>> _______________________________________________
>>>> geos-devel mailing list
>>>> geos-devel at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/geos-devel
> Libre GIS consultant/developer
> https://strk.kbt.io/services.html
