[geos-devel] cmake detailed comments
Greg Troxel gdt at lexort.com
Mon Oct 11 18:10:04 PDT 2021
As this is my first release using cmake I'm reading INSTALL etc. and
have a few comments.
0) INSTALL says;
      mkdir build && cd build && cmake -DCMAKE_BUILD_TYPE=Release ..
  Setting `CMAKE_BUILD_TYPE` to `Release` is necessary to enable compiler
  optimizations.
but CMakeLists.txt says:
  # Default to release build so packagers don't release debug builds
  set(DEFAULT_BUILD_TYPE Release)
  [set CMAKE_BUILD_TYPE from DEFAULT]
It seems to me that it's best if building without options builds what
users ought to run.  Perhaps this is changed back and forth, but it
seems better to expect people testing who want non-optimized builds for
debug clarity to use a wrapper script to build it that way.  (I tend to
have a build script for things I build from git, since I need to set up
prefix and LDFLAGS anyway.)
CMAKE_BUILD_DEVELOPER seems to be default on.
1) Doing a build without CMAKE_BUILD_TYPE gets me (among other things)
  -- GEOS: Using default build type: Release
  -- GEOS: Developer mode ENABLED
  -- GEOS: Build astyle ON
so I'm not sure if this is a release build or not.  Also, I don't
understand why astyle is built.  It's not installed, but it seems to be
a source maintenance tool that happens to be in the repo, not part of
geos.
2) not about cmake but this seems to slow down geos a lot to make tests
repeatable even though I would guess the answers obtained with extended
floats[q aren't really wrong, just different -- unless there is some
"geos computes according to IEEE754" spec, in which case it would be
nice if the comment explained that instead of talking about making tests
pass.
  # Use -ffloat-store for 32-bit builds (needed to make some tests pass)
  target_compile_options(geos_cxx_flags INTERFACE
    $<$<AND:$<CXX_COMPILER_ID:GNU>,$<EQUAL:4,${CMAKE_SIZEOF_VOID_P}>>:-ffloat-store>
3) ryu.  I am not able to follow this at all.
4) tests in top-level
The tests are written as if they are regular code; tests in general need
to be marked for special linking.  I don't see anything special there
either.
5) complexities of RPATH handling
I found the following, which I don't fully understand yet:
  https://dev.my-gate.net/2021/08/04/understanding-rpath-with-cmake/
  https://gitlab.kitware.com/cmake/community/-/wikis/doc/cmake/RPATH-handling
  https://cmake.cmake.narkive.com/6f4X1K39/change-rpath-at-the-packaging-stage
and not necessarily just about cmake but:
  https://docs.conan.io/en/latest/howtos/manage_shared_libraries/rpaths.html
6) non-pkgsrc build
I did a build using cmake from the command line, but aligned with how
one would build on a (normal ELF, not mac) system that puts software in
a prefix that isn't part of the default search path, and thus passing
CPPFLAGS and LDFLAGS for that prefix.  I realize geos is special in that
it only depends on libc and threads (and perhaps some doc programs), but
the installed geosop and library need to have a DT_RPATH section
pointing to $prefix/lib.
Doing that, the tests failed, differently from under pkgsrc, but the
installed libgeos_c was found and it ended up with both libgeos 3.9 and
3.10 both.   The reason is that the test program had both the passed-in
/usr/pkg/lib RPATH as well as the RPATH from the build directory, but
the build directory one was after the one intended for install, not
before.
I think if the build-tree RPATH used for test programs was put before
the LDFLAGS-derived RPATH, things would be better.
7) RPATH not used at install time if not in LDFLAGS
After building for prefix=/usr/pkg, and not passing in LDFLAGS, I did
  make DESTDIR=../destdir install
and got the expected files under destdir, parallel to build.  All of
geosop, libgeos_c, and geos.pc were missing RPATH.
So probably this is ok, as I realize opinions vary between platforms
about RPATH.
8) RPATH used at install time if passed via LDFLAGS
I did a build with the right values for my situation:
  CPPFLAGS=-I/usr/pkg/include LDFLAGS="-L/usr/pkg/lib -Wl,-R/usr/pkg/lib" \
and the (destdir) installed geosop, in objdump -x:
  NEEDED               libgeos_c.so.1
  NEEDED               libgeos.so.3.10.0
  NEEDED               libstdc++.so.9
  NEEDED               libm.so.0
  NEEDED               libgcc_s.so.1
  NEEDED               libc.so.12
  RPATH                /usr/pkg/lib
which looks right.
However geos.pc is missing the -Wl,-R:
  Libs: -L${libdir} -lgeos_c
Perhaps I'm supposed to be doing something different, but I haven't been
able to understand what yet.
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20211011/1ff91363/attachment.sig>
