[geos-devel] cmake detailed comments
Paul Ramsey
pramsey at cleverelephant.ca
Wed Oct 13 15:18:37 PDT 2021
Consider looking at cmake descriptions of what it intends to do with RPATH, and ways to set link flags without forcing environment variables in
https://cmake.org/cmake/help/latest/variable/CMAKE_SHARED_LINKER_FLAGS.html
https://cmake.org/cmake/help/latest/variable/CMAKE_SKIP_INSTALL_RPATH.html
https://cmake.org/cmake/help/latest/variable/CMAKE_SKIP_RPATH.html
P
> On Oct 13, 2021, at 3:17 PM, Sandro Santilli <strk at kbt.io> wrote:
> I should add, I'm using cmake version 3.16.3
> --strk;
> On Wed, Oct 13, 2021 at 11:31:54PM +0200, Sandro Santilli wrote:
>> On Wed, Oct 13, 2021 at 12:08:50PM -0400, Greg Troxel wrote:
>>> So maybe strk can test (on Linux I'm guessing):
>> Ubuntu 20.10 here
>>> build and install geos 3.9.1 as --prefix=/usr/foo
>> Done (3.9 branch of geos):
>> ./autogen.sh && \
>> ./configure --prefix=/tmp/geos && \
>> sudo make install
>> Note that after this I get:
>> $ objdump -x /tmp/geos/lib/libgeos_c.so.1.14.2 | grep RUNPATH
>> RUNPATH /tmp/geos/lib
>> I'm not sure it's relevant.
>>> build geos 3.10 by telling cmake to use /usr/foo as prefix, and
>>> passing in the environment
>>> CPPFLAGS=-I/usr/foo/include
>>> LDFLAGS="-L/usr/foo/lib -Wl,-R/usr/foo/lib"
>>> as a packaging system building everything for /usr/foo would do.
>> Done:
>> $ export CPPFLAGS=-I/tmp/geos
>> $ export LDFLAGS="-L/tmp/geos/lib -Wl,-R/tmp/geos/lib"
>> $ cmake .
>> $ make
>>> Then look at the test binaries with objdump -x, ldd, and run them.I
>>> expect they will mislink against the installed geos.
>> $ objdump -x bin/test_geos_unit | grep RUNPATH
>> RUNPATH /tmp/geos/lib:/usr/local/src/geos/geos/src/main/lib
>> $ ldd bin/test_geos_unit | grep tmp
>> libgeos_c.so.1 => /tmp/geos/lib/libgeos_c.so.1 (0x00007f0be9ead000)
>> libgeos-3.9.2.so => /tmp/geos/lib/libgeos-3.9.2.so (0x00007f0be9489000)
>>> If so, the bug in cmake or geos cmakefiles is that the extra RPATH for
>>> tests is put after the other RPATH values, rather then being put first.
>>> Or rather, that is the bug, but if you can reproduce it that's progress
>>> in understanding its scope.
>> So yes, I can reproduce the problem on a Linux system.
>> --strk;
> Libre GIS consultant/developer
> https://strk.kbt.io/services.html
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geos-devel
