[geos-devel] [GEOS] #1103: Target "tinyxml2" of type OBJECT_LIBRARY may not be linked into another target.
geos-trac at osgeo.org
Fri Oct 15 13:13:04 PDT 2021
target.
Reporter: strk | Owner: geos-devel@…
Type: defect | Status: closed
Priority: blocker | Milestone: 3.10.0
Component: Build/Install (cmake) | Version: main
Severity: Critical | Resolution: fixed
Keywords: |
Comment (by Paul Ramsey <pramsey@…>):
In [changeset:"f65bb355896a9bebc4a52a638c2c67df4959ffb7/git" f65bb35/git]:
#!CommitTicketReference repository="git"
revision="f65bb355896a9bebc4a52a638c2c67df4959ffb7"
Use OBJECT library to build ryu, so it can be fully included in
static libgeos.a, and up the cmake requirement to 3.13 to support
that change. References #1103
Ticket URL: <https://trac.osgeo.org/geos/ticket/1103#comment:8>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
