[geos-devel] cmake detailed comments
Greg Troxel gdt at lexort.com
Fri Oct 15 16:01:34 PDT 2021
Paul Ramsey <pramsey at cleverelephant.ca> writes:
> Let me know what happens on your system?
The destdir has RPATH of the prefix, and the tests have RPATH of only
the build tree.  The tests all pass (which is good, because that's
really what matters as the present discussion is about the test harness,
and not about the soundness of the resulting install).
So this approach works for geos because it's a special case, but it
won't work for programs with dependencies.
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20211015/d6a29fba/attachment.sig>
