[geos-devel] 3.10.0rc2
Andrew Hershberger
andrew.d.hershberger at gmail.com
Sat Oct 16 08:54:45 PDT 2021
GEOSwift builds & tests are passing. I also just spent some time studying
the WKT writer changes when trim is true. I like the new ryu-based
behavior. I made a slight change to the public GEOSwift API in light of
this change and drafted some documentation for the two methods that are
impacted by it:
https://github.com/GEOSwift/GEOSwift/compare/main...geos-3.10.0#diff-f5aa7242dd6b42031322468f88b5f533103e932a904ce3f2db53958798cbd3daR5-R17
Feedback is welcome if the draft docs aren't clear or accurate.
On Fri, Oct 15, 2021 at 3:53 PM Paul Ramsey <pramsey at cleverelephant.ca>
wrote:
> Here it is hopefully ready to go.
> https://download.osgeo.org/geos/geos-3.10.0rc2.tar.bz2
> P
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geos-devel
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20211016/1190b76d/attachment.html>
