[geos-devel] Default merge strategy on Gitea
Sandro Santilli strk at kbt.io
Mon Oct 18 06:05:34 PDT 2021
I've changed the default merge strategy for pull requests
on Gitea to "Rebase and Merge (no-ff)". This means a merge
commit *will* be generated even if not necessary (after rebase).
Hopefully this will help not missing the information about *who*
actually merged the contribution, taking the responsibility over
the merge.
Other merge strategies are still available, just the default changed.
It doesn't make sense to force a merge commit for your OWN
contributions, for example.
In order to do the same from other sources please use the --no-ff
switch to the git-merge command (and possibly rebase the contributed
branch against current target branch before merging, to keep history
clean).
--strk;
  Libre GIS consultant/developer
  https://strk.kbt.io/services.html
