[geos-devel] 3.10.0 Release Vote
Sandro Santilli
strk at kbt.io
Mon Oct 18 15:11:39 PDT 2021
Current main branch (4a7fd4c5c726441ecf47be31f1654a803eac52a2)
builds and passes `make check` on
- Debian GNU/Linux 10 (buster)
- Ubuntu 20.10
+1 for final
--strk;
On Mon, Oct 18, 2021 at 02:49:08PM -0700, Martin Davis wrote:
> On Mon, Oct 18, 2021 at 2:27 PM Sandro Santilli <strk at kbt.io> wrote
> > $ geosop help test
> > terminate called after throwing an instance of 'std::invalid_argument'
> > what(): stod
> > Aborted (core dumped)
> > I'd rather not install `geosop` than letting it core-dump so easily.
> > It was ticketed as https://trac.osgeo.org/geos/ticket/1126 and then
> > retargetted to 3.11 milestone, but really, I think we shouldn't
> > release with such known behaviour.
> I agree with Paul - geosop is not mission-critical, so this issue is not a
> blocker for the release.
> I will work on hardening geosop against bad inputs.
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geos-devel
Libre GIS consultant/developer
https://strk.kbt.io/services.html
