[geos-devel] [GEOS] #1135: setPrecision crashes when collapsing linearring
GEOS geos-trac at osgeo.org
Fri Oct 22 05:04:03 PDT 2021
 Reporter:  caspervdw    |       Owner:  geos-devel@…
     Type:  defect       |      Status:  new
 Priority:  major        |   Milestone:  3.10.1
Component:  Default      |     Version:  main
 Severity:  Significant  |  Resolution:
 Keywords:               |
Comment (by caspervdw):
 The same geometry with KEEP_COLLAPSED gives the surprising result
 LINESTRING (0 0, 0 0, 0 0)
Ticket URL: <https://trac.osgeo.org/geos/ticket/1135#comment:1>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
