[geos-devel] [GEOS] #1135: setPrecision crashes when collapsing linearring
GEOS geos-trac at osgeo.org
Fri Oct 29 15:06:21 PDT 2021
 Reporter:  caspervdw    |       Owner:  geos-devel@…
     Type:  defect       |      Status:  closed
 Priority:  major        |   Milestone:  3.10.1
Component:  Default      |     Version:  main
 Severity:  Significant  |  Resolution:  fixed
 Keywords:               |
Changes (by pramsey):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 Yep, the algorithm feels that a valid linestring is "better" than a
 collapsed zero-area (self-intersecting) ring. Angels dance.
Ticket URL: <https://trac.osgeo.org/geos/ticket/1135#comment:5>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
