[geos-devel] 3.9.2 Release?
Paul Ramsey
pramsey at cleverelephant.ca
Fri Oct 29 18:43:03 PDT 2021
I call for approval of a 3.9.2 release! (rah!)
The list of fixes is pretty chunky at this point and it's been a while.
+1 from me
- Bug fixes / improvements:
- Add in interrupt points in OverlayNG (#4857, Paul Ramsey)
- Fix crash in GEOSPreparedIntersects and GEOSPreparedContains for
POINT EMPTY input (Even Rouault)
- Fix IsValidOp to correctly report invalid nested MultiPolygons (#1112, Martin Davis)
- Fix BufferOp to avoid artifacts in certain polygon buffers (#1101, Martin Davis)
- Declare parameterless functions in geos_c.h as func(void) (Paul Ramsey)
- Performance improvement in SegmentNodeList (Even Rouault)
- Catch memory leaks on createPolygon failure (#1111, Paul Ramsey)
- Fix DiscreteFrechetDistance to use initial points of input lines (#1128, Martin Davis)
- Avoid stack overflow in KdTree::queryNode (Even Roualt)
- Avoid raising double overflow signals in distance calcs (Paul Ramsey)
- Fix performance issue in buffer building (Paul Ramsey)
- Fix crash when precision reducing LinearRing (#1135, Paul Ramsey)
