[geos-devel] [GEOS] #1140: GeoJSON writer is unable to handle linear rings
geos-trac at osgeo.org
Sat Oct 30 06:01:11 PDT 2021
Reporter: caspervdw | Owner: geos-devel@…
Type: defect | Status: new
Priority: minor | Milestone: 3.10.1
Component: Default | Version: 3.9.0
Severity: Unassigned | Keywords:
Linearrings are currently serialised to “null” which is a bit unexpected.
Indeed, a linearring is not in the GeoJSON spec.
I suggest converting to LineString instead. This is also done in the WKB
writer.
Ticket URL: <https://trac.osgeo.org/geos/ticket/1140>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
