[geos-devel] [GEOS] #1138: Crash on invalid GeoJSON input
GEOS geos-trac at osgeo.org
Sat Oct 30 11:34:06 PDT 2021
 Reporter:  caspervdw   |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:  3.10.1
Component:  Default     |     Version:  main
 Severity:  Unassigned  |  Resolution:
 Keywords:              |
Comment (by caspervdw):
 So the crash only occurs when GEOS is built with
 "-DCMAKE_BUILD_TYPE=Debug".
 When using -DCMAKE_BUILD_TYPE=Release, the issue goes away.
Ticket URL: <https://trac.osgeo.org/geos/ticket/1138#comment:2>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
