[geos-devel] Checking build on Solaris: patch for sqrt(2)
Paul Ramsey
pramsey at cleverelephant.ca
Sat Oct 30 15:03:00 PDT 2021
I've pushed a patch to use std::sqrt into main and 3.10.
P
> On Oct 30, 2021, at 5:18 AM, Roger Bivand <Roger.Bivand at nhh.no> wrote:
> The R archive network checks R packages and their upstream libraries on Intel Solaris (details https://www.stats.ox.ac.uk/pub/bdr/Rconfig/r-patched-solaris-x86), so a build of 3.10.0 has been tried. -DBUILD_GEOSOP=OFF was needed but is unimportant, however, sqrt(2) in geos-3.10.0/tests/unit/capi/GEOSDistanceTest.cpp:137:28 gives:
> error: call of overloaded ‘sqrt(int)’ is ambiguous
> Suggested fixes are: std::sqrt(2) or sqrt(2.), or M_SQRT2.
> Thiis is a bit small for a PR, but makes sense to fix, and comes from using a different build train.
> Roger
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geos-devel
