[geos-devel] [GEOS] #1126: geosop aborts too much :)
geos-trac at osgeo.org
Tue Sep 14 03:49:52 PDT 2021
Reporter: strk | Owner: geos-devel@…
Type: defect | Status: new
Priority: major | Milestone: 3.10.0
Component: Default | Version: main
Severity: Unassigned | Keywords:
The syntax reported by {{{ geosop }}} is not very clear, and it's typical
to just try syntaxes and be guided by errors. Instead geosop happily
aborts dumping cores whenever wrong syntax is used.
This ticket is to try at catching as many invocation errors as possible.
Ticket URL: <https://trac.osgeo.org/geos/ticket/1126>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
