[geos-devel] 3.10.0beta1
Sebastiaan Couwenberg sebastic at xs4all.nl
Thu Sep 30 23:39:56 PDT 2021
On 10/1/21 12:12 AM, Paul Ramsey wrote:
> http://download.osgeo.org/geos/geos-3.10.0beta1.tar.bz2
> Login to wiki is broken right now, so it's not on the web, but since this is testing time I guess that's not a big deal.
Since we cannot login to trac, reporting this issue here:
386/388 Test #388: test_docs
..................................................***Failed    0.09 sec
-- Doxygen issued 2121 warning(s), see
/build/geos-3.10.0~beta1/build/doc/doxygen.log
CMake Error at check_doxygen_errors.cmake:44 (message):
  /build/geos-3.10.0~beta1/build/capi/geos_c.h:254: warning: argument
  'return' of command @param is not found in the argument list of
  GEOSDistanceCallback(const void *item1, const void *item2, double
  *distance, void *userdata)
    parameter 'distance'
Kind Regards,
Bas
 GPG Key ID: 4096R/6750F10AE88D4AF1
Fingerprint: 8182 DE41 7056 408D 6146  50D1 6750 F10A E88D 4AF1
