[geos-devel] GEOS 3.10.2 Released
Paul Ramsey
pramsey at cleverelephant.ca
Sat Jan 15 13:47:01 PST 2022
The latest patch release of GEOS is now available!
http://libgeos.org/usage/download/
Changes in 3.10.2
2022-01-15
- Fixes/Improvements:
- Fix crash in MonotoneChain with empty CoordinateSequence (GH-539, Sandro Santilli)
- Fix crash in GeoJSONWriter in case of empty points (TRAC-1139, Paul Ramsey)
- Improve BuildArea performance (TRAC-1122, Sandro Santilli)
- Fix unaryUnion to avoid segfault with empty polygon (GH-501, Mike Taves)
- Fix memory leak on exception in prepared geometry (GH-506, Dan Baston)
- Iterator invalidation in rare cases (GH-508, Momtchil Momtchev)
- Infinite loop on collapsed input to MaximumInscribedCircle (Paul Ramsey)
- Write LinearRing to GeoJSON as LineString (TRAC-1140, Paul Ramsey)
- Fix PolygonEarClipper to handle collapsed corners (GH-526, Martin Davis)
- Fix GEOSSTRtree_remove for empty tree (GH-544, Dan Baston)
- Fix crash on query of STRtree with removed items (GH-545, Dan Baston)
