[geos-devel] Released 3.7.4, 3.8.3, 3.9.3, 3.10.3
Paul Ramsey pramsey at cleverelephant.ca
Fri Jun 3 09:44:46 PDT 2022
Hot and tasty downloads available!
https://libgeos.org/posts/2022-06-03-geos-3-10-3-released/
Mostly in 3.10, as one would expect.
- Fixes/Improvements:
- VoronoiDiagramBuilder::setSites(const CoordinateSequence&) return sorted (GH-551)
- Add SnappingNoder seeding (Martin Davis)
- Fix RelateOp (and intersects predicate) for lines with intersections very near boundary (GH-570, Martin Davis)
- Fix segfault in Hausdorff distance with empty geometries (GH-569)
- Fix inf loop in PolygonTriangulator (GH-574, Andrew Stelter)
- Fix short circuit from TemplateSTRtree query (GH-577, Andrew Stelter)
- Fix IsValidOp to handle repeated node points (JTS-845, Martin Davis)
- Fix IsSimpleOp to handle closed LineStrings with repeated endpoints (JTS-851, Martin Davis)
- Add OverlayNG area check heuristic (JTS-812, Paul Ramsey)
- Improve test_geos_unit application error checking and reporting (Martin Davis)
- Fix LengthIndexedLine (via LengthLocationMap fix) (JTS-859, Martin Davis)
- Fix PolygonHoleJoiner (JTS-862, Martin Davis)
- Fix crash in GeometryNoder on empty intpu (GH-601, Paul Ramsey)
- Handle case where user sets explicit absolute lib and include dirs (GH-608, Paul Ramsey)
- Fix MinimumDiameter getMinimumRectangle for flat input (JTS-875, Martin Davis)
- Fix HilbertEncoder difference in ARM vs x64 (GH-579, Paul Ramsey)
- Fix BufferOp inverted ring check (JTS-878, Martin Davis)
