[geos-devel] mingw64 file libs changed
Regina Obe lr at pcorp.us
Mon Jun 13 16:31:47 PDT 2022
So what's your interest in mingw64?
Are you building mingw64 packages on Fedora?
The thing is libgeos_c.dll never changes (I'm fine with a c_1.dll for that)
But the c++ api is unstable.
So why do I want this changing in every micro release when all that should be used is the C-API by packagers which is stable?
> -----Original Message-----
> From: Sandro Mani [mailto:manisandro at gmail.com]
> Sent: Monday, June 13, 2022 1:33 PM
> To: GEOS Development List <geos-devel at lists.osgeo.org>; Regina Obe
> <lr at pcorp.us>
> Subject: Re: [geos-devel] mingw64 file libs changed
> Hi
> I'm actually packaging for Fedora.
> In short, autotools (and more recently, meson) both add suffixes to the
> shared library names with version number, cmake does not do so, but
> apparently just because no-one actually pursued it [1].
> Why is it useful?
> - Quickly picking out which packages need to be rebuild when a dependent
> package which carries an ABI incompatibilty is updated (i.e. dnf repoquery --
> whatrequires 'mingw64(libgeos_c-1.dll)'). This is *very* useful for packaging.
> - Actually even noticing when an ABI incompatibility arises. Packagers often
> spot ABI incompatibilities when the so version of a library is bumped. This
> clearly requires upstream to properly set and update the soversion.
> - For the same reason as above, versioned requires between packages
> - Potentially, allowing parallel versions without DLL name collisions
> Thanks
> Sandro
> [1] https://gitlab.kitware.com/cmake/cmake/-/issues/21716
> On 13.06.22 19:10, Regina Obe wrote:
> > Is there a way in CMake to make this an option.
> > I wouldn't want to inconvenience someone to satisfy me.
> > If I could have a switch I can turn on to get the old CMAKE behavior
> > I'd be very happy.
> > My use case is different from Manisandro. He's probably packaging for
> > pacman.
> > In my case, I can only ever have one geos version for each version of
> > PostgreSQL. Those all live in the respective PostgreSQL versioned
> > folders
> > PostgreSQL/14/bin   , PostgreSQL/15/bin  ...
> >> From: geos-devel [mailto:geos-devel-bounces at lists.osgeo.org] On
> >> Behalf Of Paul Ramsey
> >> Sent: Monday, June 13, 2022 12:32 PM
> >>> On Jun 13, 2022, at 9:29 AM, Regina Obe <lr at pcorp.us> wrote:
> >>> Okay guess the question has been answered by
> https://github.com/manisandro/geos/commit/927e442ab1da361d3f487e2b6
> >> 20a
> >>> 878dd1
> >>> 1f191d
> >>> I'll have to live with it moving forward.
> >> I wouldn't say so necessarily. I took in a commit from someone with
> >> an opinion on MinGW (I had no opinion, so I took the commit) but the
> > discussion
> >> in GDAL shows other MinGW people with other opinions, and,
> >> importantly I think, the folks at CMake (who see a *lot* of build
> >> cases) have not chosen
> > to
> >> just slam in a file prefix on MinGW targets that have an SOVERSION
> >> set,
> > even
> >> though they do so on when generating outputs for other platforms.
> >> So I'd say it is very much up to you, as someone who has MinGW opinions.
> >> P
> >>> Thanks,
> >>> Regina
> >>>> From: Regina Obe [mailto:lr at pcorp.us]
> >>>> Sent: Monday, June 13, 2022 12:01 PM
> >>>> To: 'GEOS Development List' <geos-devel at lists.osgeo.org>
> >>>> Subject: mingw64 file libs changed
> >>>> I mentioned this on IRC, and Paul is looking into why the change
> >>>> was
> >> made.
> >>>> I'm mentioning here in case someone knows the reason.  Why was this
> >>>> change made?
> >>>> The library files on mingw64 changed:
> >>>> For geos < 3.11 the files were
> >>>> libgeos.dll, libgeos_c.dll
> >>>> For geos 3.11 (including the just released 3.11.0beta1)
> >>>> libgeos_c-1.dll, libgeos-3.11.0.dll
> >>> _______________________________________________
> >>> geos-devel mailing list
> >>> https://lists.osgeo.org/mailman/listinfo/geos-devel
