[geos-devel] mingw64 file libs changed
Roger Bivand Roger.Bivand at nhh.no
Tue Jun 14 03:59:10 PDT 2022
In R >= 4.2, Windows static linked binary packages linking to GEOS use
MXE, locally updating the MXE use of GEOS 3.6.2 to 3.9.1:
https://svn.r-project.org/R-dev-web/trunk/WindowsBuilds/winutf8/ucrt3/toolchain_libs/mxe/src/geos.mk
We currently hot-patch geos-config to modify it for static libs:
https://svn.r-project.org/R-dev-web/trunk/WindowsBuilds/winutf8/ucrt3/toolchain_libs/mxe/src/geos-1-fixes.patch
We could hot-patch files in a GEOS >= 3.11.0 tarball to remove
instructions creating versioned libraries, but have not yet tested RC1. R
packages also need to list static linked libraries by name, and revising
each of a dozen or so at each GEOS release would be error prone.
Is a cmake option a way to satisfy both those needing versioned, or
unversioned library names?
Does anyone else use MXE; if so, might it make sense to feed changes in
GEOS forward to MXE?
Best wishes,
Roger
Roger Bivand
Emeritus Professor
Department of Economics, Norwegian School of Economics,
Postboks 3490 Ytre Sandviken, 5045 Bergen, Norway.
e-mail: Roger.Bivand at nhh.no
https://orcid.org/0000-0003-2392-6140
https://scholar.google.no/citations?user=AWeghB0AAAAJ&hl=en
