[geos-devel] mingw64 file libs changed
Regina Obe
lr at pcorp.us
Tue Jun 14 09:21:17 PDT 2022
In my case, I need the c++ library statically linked into the geos C-api.
I need the geos c-API shared but not the c++ one. The main reason for need
of c-api shared is all the extensions I ship rely on that.
So I don't want both statically linked.
Also for regression testing I do want to replace the c-lib without having to
recompile all my extensions.
Dan and strk had suggested a way to have the c++ be object .a so it can be
statically linked to the c lib.
I'm not sure how to do that in Cmake or if it is even currently possible.
So Sandro - my annoyance with your change is now I have this extra c++ lib
to worry about which was always a static name before and now is changing
with each micro release.
Thanks,
Regina
> -----Original Message-----
> From: geos-devel [mailto:geos-devel-bounces at lists.osgeo.org] On Behalf Of
> Sandro Mani
> Sent: Tuesday, June 14, 2022 8:00 AM
> To: Roger.Bivand at nhh.no; GEOS Development List <geos-
> devel at lists.osgeo.org>
> Subject: Re: [geos-devel] mingw64 file libs changed
> Just a note: library versioning only applies to shared libraries, static
libraries
> are unversioned. And FWIW, import libraries are also unversioned. So no
link
> command should be affected (unless you are linking against the dll shared
> library rather than the dll.a import library).
> Sandro
> On 14.06.22 12:59, Roger Bivand wrote:
> > In R >= 4.2, Windows static linked binary packages linking to GEOS use
> > MXE, locally updating the MXE use of GEOS 3.6.2 to 3.9.1:
> > https://svn.r-project.org/R-dev-web/trunk/WindowsBuilds/winutf8/ucrt3/
> > toolchain_libs/mxe/src/geos.mk
> > We currently hot-patch geos-config to modify it for static libs:
> > toolchain_libs/mxe/src/geos-1-fixes.patch
> > We could hot-patch files in a GEOS >= 3.11.0 tarball to remove
> > instructions creating versioned libraries, but have not yet tested
> > RC1. R packages also need to list static linked libraries by name, and
> > revising each of a dozen or so at each GEOS release would be error
prone.
> > Is a cmake option a way to satisfy both those needing versioned, or
> > unversioned library names?
> > Does anyone else use MXE; if so, might it make sense to feed changes
> > in GEOS forward to MXE?
> > Best wishes,
> > Roger
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geos-devel
