[geos-devel] mingw64 file libs changed
Regina Obe
lr at pcorp.us
Wed Jun 15 09:32:37 PDT 2022
Now I see libgeos_c-1.dll and libgeos.dll.
It's different from 3.9 and 3.10, which had libgeos_c.dll for the c-api lib
file but I'm fine with that. Just want to make sure you intended to keep
that change.
Thanks,
Regina
> -----Original Message-----
> From: geos-devel [mailto:geos-devel-bounces at lists.osgeo.org] On Behalf Of
> Paul Ramsey
> Sent: Wednesday, June 15, 2022 12:17 PM
> To: GEOS Development List <geos-devel at lists.osgeo.org>
> Cc: Roger.Bivand at nhh.no
> Subject: Re: [geos-devel] mingw64 file libs changed
> This is in main now.
> P
> > On Jun 14, 2022, at 11:05 AM, Regina Obe <lr at pcorp.us> wrote:
> > Sandro,
> > I'm not sure I understand your question.
> > The issue is not the linking of my code. It's the dependency of
> > libgeos_c-1.dll
> > To libgeos-3.11.0.dll
> > I am trying to get rid of.
> > All my code ends up having a dependency on libgeos_c-1.dll (before
> > libgeos_c.dll) Which before linked to a unversioned libgeos.dll (this
> > libgeos.dll was always called that so could be cleanly removed and
> > replaced)
> > I don't care about if the c dll is called libgeos_c-1.dll or
libgeos_c.dll.
> > It's the annoyance of that c++ dll changing with every micro release.
> > Cause these are harder to predict and uninstall as part of an install
process.
> >> From: Sandro Mani [mailto:manisandro at gmail.com]
> >> Sent: Tuesday, June 14, 2022 1:50 PM
> >> To: Regina Obe <lr at pcorp.us>; 'GEOS Development List' <geos-
> >> devel at lists.osgeo.org>; Roger.Bivand at nhh.no
> >> Can you point me to the Makefile / ... which is doing this linking?
> >> It should never be necessary to point to a versioned shared library
> >> name in a link command line. Static libraries are unversioned, and
> >> for the dynamic libraries the corresponding import libraries are also
> unversioned.
> >> Sandro
> >> On 14.06.22 18:21, Regina Obe wrote:
> >>> In my case, I need the c++ library statically linked into the geos
C-api.
> >>> I need the geos c-API shared but not the c++ one. The main reason
> >>> for need of c-api shared is all the extensions I ship rely on that.
> >>> So I don't want both statically linked.
> >>> Also for regression testing I do want to replace the c-lib without
> >>> having to recompile all my extensions.
> >>> Dan and strk had suggested a way to have the c++ be object .a so it
> >>> can be statically linked to the c lib.
> >>> I'm not sure how to do that in Cmake or if it is even currently
possible.
> >>> So Sandro - my annoyance with your change is now I have this extra
> >>> c++ lib to worry about which was always a static name before and now
> >>> is changing with each micro release.
> >>> Thanks,
> >>> Regina
> >>>> Behalf Of Sandro Mani
> >>>> Sent: Tuesday, June 14, 2022 8:00 AM
> >>>> To: Roger.Bivand at nhh.no; GEOS Development List <geos-
> >>>> Just a note: library versioning only applies to shared libraries,
> >>>> static
> >>> libraries
> >>>> are unversioned. And FWIW, import libraries are also unversioned.
> >>>> So no
> >>> link
> >>>> command should be affected (unless you are linking against the dll
> >>>> shared library rather than the dll.a import library).
> >>>> Sandro
> >>>> On 14.06.22 12:59, Roger Bivand wrote:
> >>>>> In R >= 4.2, Windows static linked binary packages linking to GEOS
> >>>>> use MXE, locally updating the MXE use of GEOS 3.6.2 to 3.9.1:
> >>>>> https://svn.r-project.org/R-dev-web/trunk/WindowsBuilds/winutf8/uc
> >>>>> rt
> >>>>> 3/
> >>>>> toolchain_libs/mxe/src/geos.mk
> >>>>> We currently hot-patch geos-config to modify it for static libs:
> >>>>> rt 3/ toolchain_libs/mxe/src/geos-1-fixes.patch
> >>>>> We could hot-patch files in a GEOS >= 3.11.0 tarball to remove
> >>>>> instructions creating versioned libraries, but have not yet tested
> >>>>> RC1. R packages also need to list static linked libraries by name,
> >>>>> and revising each of a dozen or so at each GEOS release would be
> >>>>> error
> >>> prone.
> >>>>> Is a cmake option a way to satisfy both those needing versioned,
> >>>>> or unversioned library names?
> >>>>> Does anyone else use MXE; if so, might it make sense to feed
> >>>>> changes in GEOS forward to MXE?
> >>>>> Best wishes,
> >>>>> Roger
> >>>> _______________________________________________
> >>>> geos-devel mailing list
> >>>> https://lists.osgeo.org/mailman/listinfo/geos-devel
