[geos-devel] build failure of 3.10.3 on smartos (= illumos)
Greg Troxel
gdt at lexort.com
Tue Jun 21 03:48:26 PDT 2022
Also, I should point out that we are carrying a patch, which seems like
it can't be related, but:
$NetBSD: patch-util_geosop_cxxopts.hpp,v 1.1 2022/03/27 13:33:21 tnn Exp $
On at least modern SunOS, int8_t is typedef'd to char, so parse_value()
that operates on int8_t& conflicts with the one that operates on char&.
--- util/geosop/cxxopts.hpp.orig 2022-01-15 21:14:55.000000000 +0000
+++ util/geosop/cxxopts.hpp
@@ -677,12 +677,14 @@ namespace cxxopts
integer_parser(text, value);
+#if !defined(__sun)
inline
void
parse_value(const std::string& text, int8_t& value)
+#endif
inline
void
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20220621/4613611e/attachment.sig>
