[geos-devel] GEOS support for Visual Studio 2015
Paul Ramsey
pramsey at cleverelephant.ca
Thu Nov 17 04:28:40 PST 2022
I have no skin in the game, so I'm OK for dropping MSVC 2015 going forward... for what that's worth (nothing).
P
> On Nov 16, 2022, at 4:44 PM, Regina Obe <lr at pcorp.us> wrote:
> I vote for drop for GEOS 3.12+
> I guess technically we can’t drop for 3.11 and below since those would be considered breaking changes.
> I personally don’t have an interest in MSVC in general and I only have MSVC 2019 installed if I cared to use MSVC for anything. So dropping MSVC2015 is fine with me.
> FWIW MS changed their policy of visual studio redistributable, so the latest redistributable covers 2015, 2017, 2019, and 2022
> https://learn.microsoft.com/en-us/cpp/windows/latest-supported-vc-redist?view=msvc-170
> So dropping the MSVC2015 I see only as an inconvenience to developers who for whatever reason choose to stick with 2015, of those they probably don’t need to run newer GEOS either. MSVC2015 main support ended 2 years ago and is now on extended life support. https://learn.microsoft.com/en-us/lifecycle/products/visual-studio-2015
> Thanks,
> Regina
> From: geos-devel [mailto:geos-devel-bounces at lists.osgeo.org] On Behalf Of Daniel Baston
> Sent: Wednesday, November 16, 2022 7:19 PM
> To: GEOS Development List <geos-devel at lists.osgeo.org>
> Subject: [geos-devel] GEOS support for Visual Studio 2015
> Hi,
> Not for the first time, I've been testing some code changes that work in all of our CI environments except for Visual Studio 2015. We recently removed support for gcc 4.8 and I'm wondering if we should consider removing support for MSVC 2015 in the same release. Like gcc 4.8, MSVC 2015 lacks 100% C++11 support. It also requires us to maintain an AppVeyor CI setup solely for this compiler. Is there any particular interest in this compiler, or can we remove it and save some effort implementing workarounds?
> Dan
> geos-devel mailing list
> https://lists.osgeo.org/mailman/listinfo/geos-devel
