[geos-devel] CoordinateArraySequence == CoordinateSequence
Daniel Baston
dbaston at gmail.com
Tue Oct 4 08:15:03 PDT 2022
GEOS is pretty tied to the interleaved representation. LIke JTS, it uses
Coordinate struct to pass around coordinates, with fields for X, Y, and Z
values. If we wanted to support a separate-array representation, we'd
either need to either change our Coordinate struct to store pointers to the
X and Y values, or remove the Coordinate struct altogether and have
algorithms ask a CoordinateSequence for X and Y values directly. Both seem
like a large effort to eliminate the first of what is likely several copies.
That said, an updated CoordinateSequence could still bring about more
incremental improvements in this space:
- Eliminating the virtual function overhead of coordinate access (this is
what the linked PR does)
- Allowing the use of an external buffer instead of the one managed by
std::vector, so we could have a zero-copy method of bringing data into GEOS
from an interleaved buffer
- Making Coordinate a bit more generic, so we could avoid storing the Z
value (or requiring it in an external buffer) in the cases where we don't
want it.
Dan
On Thu, Sep 29, 2022 at 11:38 AM Joris Van den Bossche <
jorisvandenbossche at gmail.com> wrote:
> We are currently having a discussion about interleaved (XYXY) vs separate
> arrays (XX YY) in the GeoArrow context (
> https://github.com/geopandas/geo-arrow-spec/pull/26), and I was wondering
> if the GEOS developers have thoughts on that topic (whether it was ever
> specifically discussed if the current approach of CoordinateArraySequence
> to store all dimensions interleaved is the best option for GEOS or if
> separate arrays could be considered as well). But so the above already
> touches upon that topic, and I also noticed related discussion at
> https://github.com/libgeos/geos/pull/674#issuecomment-1245741058
> In general, from the Shapely/GeoPandas side, we are certainly interested
> in being able to create CoordinateSequences zero-copy from arrays of
> coordinates (the current GEOSCoordSeq_copyFromBuffer_r et al already helps
> a lot though, although it would be nice if it could use a single memcpy for
> 2D as well (related to underlying memory storage above) or even avoid this
> one memcpy).
> Best,
> Joris
> On Wed, 24 Aug 2022 at 13:50, Daniel Baston <dbaston at gmail.com> wrote:
>> This has come up a few times and despite some pushback from users [1] I
>> agree that the benefits of the simplification probably outweigh the costs.
>> Replacing CoordinateSequence with a concrete implementation is top on my
>> list for the GDAL grant work [2] that I will be available to begin on
>> September 1. My general plan was to
>> 1. Replace CoordinateSequence with CoordinateArraySequence and check
>> performance improvement. Even without algorithmic improvements like the
>> ones you're talking about, I would expect that devirtualizating Coordinate
>> access, and the consequent enabling of inlining, will provide a good
>> benefit across the board.
>> 2. Replace CoordinateArraySequence with a class backed by a buffer of
>> doubles to support future generalization of Coordinate dimension. This may
>> also allow us to offer zero-copy to clients that happen to use an XYXY
>> representation internally (PostGIS)
>> 3. Experiment with a union or std::variant to sneak in an optimized
>> stack-only implementation for Points
>> I do wonder if our embrace of XYXY is the best choice here and if XXYY
>> would enable vectorization in some cases. That would be a pretty invasive
>> experiment to perform across the whole library, but maybe we could look at
>> something like OrientationIndex in isolation.
>> Dan
>> [1] https://github.com/libgeos/geos/issues/564
>> [2] https://lists.osgeo.org/pipermail/geos-devel/2022-March/010672.html
>> On Tue, Aug 23, 2022 at 3:22 PM Paul Ramsey <pramsey at cleverelephant.ca>
>> wrote:
>>> One of the things that tinkering with the SegmenString layer of overlay
>>> brought out to me was the extent to which we construct CoordinateSequence
>>> almost exclusively out of CoordinateArraySequence. Like, all the time. At
>>> yet, because we handle those CoordinateArraySequence at the API level
>>> almost exclusively as CoordinateSequence we lose the ability to do some
>>> handy optimizations.
>>> Like, if one were going to (as one does on every single
>>> CoordinateSequence that enters the overlay code)
>>> (1) test if there are repeated points and
>>> (2a) remove any if there are
>>> (2b) just return the untouched CoordinateSequence if there aren't
>>> a useful pattern would be for ::hasRepeatedPoints() to return/populate a
>>> list of indexes at which repeated points appear and for
>>> ::removeRepeatedPoints() to do bulk copies of all the points in between
>>> those indexes. This is foreclosed by the CoordinateSequence API, you can
>>> play this trick nicely with a std::vector living underneath, but the API
>>> doesn't let us see that (in fact) that's what we have 99.9% of the time.
>>> So, one obvious thing to do would be to remove the virtual methods in
>>> CoordinateSequence and pull the implementation up to that level,
>>> std::vector and all, and give up on the idea of an abstract interface that
>>> we don't actually use. For a handful of use cases, where data access cost
>>> is greater than computation cost (area, length, distance(?), some others
>>> (?)) this might be "bad" in some theoretical way, but note that currently
>>> we still don't actually have that abstract layer in place for a zero copy
>>> computation. Removing the virtual methods and inheritance from
>>> CoordinateSequence would foreclose an option that (a) we seem unlikely to
>>> ever deliver on and (b) has narrow performance benefits even if we did
>>> deliver on it.
>>> Meanwhile, the flip case seems to likely have a *lot* of performance
>>> benefits just hanging around waiting to be harvested. Coordinate access
>>> without going through the inheritance structure; access to some bulk
>>> operations like the repeated points case.
>>> For the "zero copy" crew, I feel like a big chunk of gains for them
>>> could be harvested by ensuring that point-based operations are available
>>> and don't require construction of a full Point() object. So things like
>>> PreparedGeometry->intersects(x, y). Sure, you still have to copy in your
>>> polygon feature and prepare it, but much of the overhead in that would
>>> still exist in a "zero copy" paradigm (all the internal index buildings).
>>> Meanwhile you'd no longer need to create a full Point() to do a
>>> point-in-poly test, and that would hopefully be a big win for most users.
>>> Random thoughs on a sunny day,
>>> P
>>> geos-devel mailing list
>>> geos-devel at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geos-devel
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20221004/e487d5c0/attachment.htm>
