[geos-devel] CoverageUnion
Martin Davis
mtnclimb at gmail.com
Wed Apr 19 21:22:42 PDT 2023
On Tue, Apr 18, 2023 at 5:24 PM Daniel Baston <dbaston at gmail.com> wrote:
> but performs better than the old algorithm if the inputs are pre-sorted
> (as they are in the old algorithm). Maybe the same sorting should be added
> to the NG version.
The first step in the union algorithm is to identify segments which are
unique (duplicate segments are removed). This is done by adding and
removing segments to/from a set. I wonder if it would be faster to simply
sort all the segments, and scan the list retaining only unique segments?
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20230419/0338ec21/attachment.htm>
