[geos-devel] CoverageUnion
Sandro Santilli
strk at kbt.io
Thu Apr 27 14:16:05 PDT 2023
On Wed, Apr 26, 2023 at 12:45:41PM -0700, Paul Ramsey wrote:
> I am tempted to change the contract and document that
> a validity check is a precondition for getting "sensible" results on
> output.
Where's the contract ? I was curious to understand what would
ST_CoverageUnion do for me but only found these short paragraphs:
https://github.com/libgeos/geos/blob/62c928c9f37957c62fab8db69e6c8efd26ce4085/include/geos/coverage/CoverageUnion.h#L33-L40
https://github.com/libgeos/geos/blob/62c928c9f37957c62fab8db69e6c8efd26ce4085/include/geos/coverage/CoverageUnion.h#L48-L53
Those two paragraphs boils down to:
Unions a polygonal coverage in an efficient way.
Valid polygonal coverage topology allows merging polygons in a very efficient way.
Takes: the polygons in the coverage (a vector of Geometry pointers)
Returns: the union of the coverage polygons (a Geometry unique pointer)
Questions I have are:
- What is a "valid polygonal coverage" ?
- Do shared edges need to contain the exact same vertices ?
The answer seem to be in the PostGIS pull request to expose the
functionality [1], but it would be useful to have it in the GEOS
(and JTS?) side too. For easier porting of JTS fixes I also find
it useful to encode the "last commit of JTS" in a comment in the
top of each file.
[1] https://github.com/postgis/postgis/pull/731#issue-1683980686
In general GEOS functions are (not sure if documented as such) expected to take
a valid input for their return to be defined. There should be very few exceptions
to this, maybe only the recent MakeValid.
--strk;
