[geos-devel] [GEOS] #932: improve static-library build
GEOS geos-trac at osgeo.org
Mon Aug 28 14:29:12 PDT 2023
 Reporter:  basiliscos  |       Owner:  geos-devel@…
     Type:  patch       |      Status:  closed
 Priority:  major       |   Milestone:  3.10.0
Component:  Default     |     Version:  main
 Severity:  Unassigned  |  Resolution:  fixed
 Keywords:              |
Comment (by Mike Taves <mwtoews@…>):
 In [changeset:"40da3a61338068549eabe19f68d1cf082cece853/git"
 40da3a61/git]:
 {{{#!CommitTicketReference repository="git"
 revision="40da3a61338068549eabe19f68d1cf082cece853"
 Fix CMake on Windows with Visual Studio (#945)
 Avoid setting CMAKE_BUILD_TYPE default when multi-config generators are
 used.
 Avoid setting CMAKE_BUILD_TYPE STRINGS property if it is not a cache
 variable. This avoids CMake errors if CMAKE_BUILD_TYPE isn't set on the
 command-line.
 Closes #932
Ticket URL: <https://trac.osgeo.org/geos/ticket/932#comment:5>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
