[geos-devel] [gdal-dev] Report on GEOS maintenance grant
Andrew Hershberger
andrew.d.hershberger at gmail.com
Mon Feb 27 09:59:26 PST 2023
Dan, thanks on behalf of the GEOSwift project and everyone who uses it, especially your work on thread/context-specific interrupt handlers ! I'm looking forward to updating to a new GEOS with these improvements soon!
Sent via Superhuman ( https://sprh.mn/?vip=andrew.d.hershberger@gmail.com )
On Mon, Feb 27, 2023 at 12:12 PM, Paul Ramsey < pramsey at cleverelephant.ca > wrote:
> Thanks so much Dan, it’s been great having you on patrol these last few
> months, and the big changes you got through lay a nice foundation for the
> future of the library.
> P
>> On Feb 27, 2023, at 9:02 AM, Howard Butler < howard@ hobu. co (
>> howard at hobu.co ) > wrote:
>>> On Feb 27, 2023, at 8:32 AM, Daniel Baston < dbaston@ gmail. com (
>>> dbaston at gmail.com ) > wrote:
>>> Hi All,
>>> As February comes to a close, I’m winding down the GEOS maintenance work
>>> that the GDAL PSC funded in 2022 [1]. I appreciate the opportunity to do
>>> this work and am especially thankful to those who reported issues,
>>> reviewed pull requests, or participated in discussions about this work.
>>> For anyone who’s interested, I wanted to share a few of the highlights
>>> from my perspective.
>>> New functionality: GEOS now supports reading, writing, and overlay of
>>> geometries with an M dimension. I added a number of C API utility
>>> functions requested by client library developers: GEOSLineSubstring,
>>> GEOSEqualsIdentical, and thread/context-specific interrupt handlers. I
>>> also brought in clustering algorithms such as DBSCAN that were previously
>>> only available in PostGIS.
>>> Performance enhancements: I found some nice performance wins in key GEOS
>>> algorithms such as geometry intersection testing (GEOSIntersects and
>>> GEOSPreparedIntersects), distance (GEOSPreparedDistance and
>>> GEOSPreparedDistanceWithin) and buffering complex geometries. There are
>>> also some gains in core internal classes such as CoordinateSequence and
>>> STRtree that deliver across-the-board gains.
>>> Project maintenance. I was able to simplify our CI setup by removing the
>>> use of Azure and AppVeyor services and bringing the associated
>>> environments into GitHub Actions, write a harness for performance testing
>>> and visualization, and perform code cleanup such as migrating from raw to
>>> managed pointers in key classes. I resolved a number of long-standing bug
>>> reports with WKT input/output, geometry simplification, and
>>> crashes/incorrect results from multiple algorithms in edge cases such as
>>> empty geometry inputs.
>>> Not everything panned out, or at least not yet. Something we’ve wanted in
>>> GEOS for a long time is the ability to create a GEOS geometry directly
>>> from an external memory buffer, such as a PostGIS LWGEOM or a GDAL
>>> OGRGeometry (“zero-copy”). I added experimental support for this, but so
>>> far I haven’t found a case where it offers much performance benefit.
>>> Dan
>>> [1] https:/ / lists. osgeo. org/ pipermail/ gdal-dev/ 2022-February/ 055433.
>>> html ( https://lists.osgeo.org/pipermail/gdal-dev/2022-February/055433.html
>> Dan,
>> Thank you so much for taking on these efforts in a way that was both
>> reactive to the community and aligned with the stated goals of the
>> project. The project was to move GEOS forward on topics that do not
>> achieve outside contribution, and you took on some tough topics that
>> reached up and down the codebase to provide easier to use APIs and
>> performance wins that will be fun to show off in other contexts like OGR,
>> Shapely, and PostGIS usages.
>> Thanks,
>> Howard
>> gdal-dev mailing list
>> gdal-dev@ lists. osgeo. org ( gdal-dev at lists.osgeo.org )
>> https:/ / lists. osgeo. org/ mailman/ listinfo/ gdal-dev (
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev )
> geos-devel mailing list
> geos-devel@ lists. osgeo. org ( geos-devel at lists.osgeo.org )
> https:/ / lists. osgeo. org/ mailman/ listinfo/ geos-devel (
> https://lists.osgeo.org/mailman/listinfo/geos-devel )
URL: <http://lists.osgeo.org/pipermail/geos-devel/attachments/20230227/55470475/attachment.htm>
