[geos-devel] Switching to C++14
Paul Ramsey
pramsey at cleverelephant.ca
Wed Jan 18 10:38:24 PST 2023
So far all sounds very safe and sound... +1
> On Jan 18, 2023, at 5:37 AM, Daniel Baston <dbaston at gmail.com> wrote:
> What is the current lowest version? C++11 requires gcc 4.9, strictly,
> but 4.8 is often enough. Is this "4.9 worked before and will still
> work", or something else.
> The lowest gcc version we test is 5. We know that GEOS does not build with gcc 4.8
> because we sometimes return std::unique_ptr<Derived> from functions with return
> type std::unique_ptr<Base>. I have not tried building this pull request with gcc 4.9
> (it does not appear to be available on the GitHub runner), but C++14 auto lambdas
> are claimed to be supported beginning in 4.9.
> Dan
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geos-devel
