[geos-devel] 3.12.0beta1
    Sebastiaan Couwenberg
    sebastic at xs4all.nl
    Thu Jun  8 09:41:21 PDT 2023
test_docs fails:
  test 466
          Start 466: test_docs
  466: Test command: /usr/bin/cmake "-D"
"DOXYGEN_LOGFILE="/build/geos-3.12.0~beta1/build/doxygen/doxygen.log""
"-P" "/build/geos-3.12.0~beta1/build/doxygen/check_doxygen_errors.cmake"
  466: Working Directory: /build/geos-3.12.0~beta1/build/doxygen
  466: Test timeout computed to be: 1500
  466: -- Doxygen issued 2476 warning(s), see
  466: CMake Error at check_doxygen_errors.cmake:44 (message):
  466:
/build/geos-3.12.0~beta1/include/geos/coverage/CoverageRingEdges.h:76:
  466:   warning: found documented return type for
  466:   geos::coverage::CoverageRingEdges::CoverageRingEdges that does
not return
  466:   anything
  466:
  466:
  464/466 Test #466: test_docs
..................................................***Failed    0.08 sec
    geos::coverage::CoverageRingEdges::CoverageRingEdges that does not
return
    anything
  99% tests passed, 1 tests failed out of 466
  Total Test time (real) =   9.26 sec
  The following tests FAILED:
          466 - test_docs (Failed)
  Errors while running CTest
Kind Regards,
Bas
  GPG Key ID: 4096R/6750F10AE88D4AF1
Fingerprint: 8182 DE41 7056 408D 6146  50D1 6750 F10A E88D 4AF1
